Error(18948): Error message received from device: Internal error. (Subcode 0x001A, Info 0x00000000,
Providing free running refCLK and cannot use it is 2 different story. Hope you understand that.
Can i have your agilex device part number?
- alexislms4 years ago
Contributor
Sorry, I don't understand what you said.
You first suggest it might be a free-running refclk problem, then you suggest me "try to remove them in the design". Removing the IP or removing the refclks isn't a solution, either way, it means to stop using the IP hence my surprise.
Nevertheless, I might have misunderstood something.
After days of trying, I find out the problem comes from the devkit's example designs and the user guide of the R-tile.
Currently, my design doesn't use most of the F-tiles and the other R-tile. Please confirm I can safely stop using the assignment.
The part number was provided in a previous message: AGIB027R29A1E2VR0
And if helpful, the devkit's S/N: AGIPCIE8000248 (DK-DEV-AGI027RES)
