alexislms
Contributor
4 years agoError(18948): Error message received from device: Internal error. (Subcode 0x001A, Info 0x00000000,
Same question:
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Error-18948-Error-message-received-from-device-Detected/td-p/1272326?profile.language=de
While programming the design, ...
YuanLi_S_Intel
4 years agoAssuming you are using Stratix 10. You may take a look at the following solution:
https://www.intel.com/content/www/us/en/support/programmable/articles/000086828.html
alexislms
Contributor
4 years ago@YuanLi_S_Intel Thank you for your help.
I'm using Agilex I-series development kit with Quartus Pro 22.1.
I believe your solution is more for PCB designer, I can't be sure the refclk is running since I use the Intel devkit using the pins in the golden_top.
