RubenPadial
Contributor
2 years agoError(16045): Instance "dummy_0" instantiates undefined entity "arria10_SoC_mSGDMA_dummy_0"
Hello, I am working in a project to be familiar with Platform Designer and msgDMA in Intel Arria 10 SoC platform. I have instantiated 2 msgDMA (ST-MM and MM-ST) and a SoC IPs as well as a dummy cus...
ShengN_altera
2 years agoHi,
I had created a platform designer system with 2 MSGDMA and custom module dummy.vhd in between the 2 MSGDMA. Compilation run successfully without error check attached .qar.
Make sure the entity name is correct and matching. Try to create a new custom IP with updated dummy.vhd. It's better also to re-generate the .qsys to get the updated module files.
Sheng
