Error(11176): quartus\bin64\ccl_ver_jni_stub.dll: Can't find dependent libraries
Hello everyone,
I use Quartus Prime Pro and I compile code for Arria10 and Cyclone10 targets.
Since few days, during Analysis & Synthesis, an Error 11176 occur :
...quartus\bin64\ccl_ver_jni_stub.dll: Can't find dependent libraries
Did someone have already this issue and how to resolve it ?
Thanks in advance,
Vincent
- RichardT_altera
Hi @VFlav
Could you check whether the ccl_ver_jni_stub.dll is found in the ...quartus\bin64? I suspect this might be due to bad Quartus installation.
Try to re-install the latest Quartus Pro version 21.2 and check if the issue persists.
You may download it from: https://fpgasoftware.intel.com/21.2/?edition=pro
Richard Tan
- VFlav
Thanks for your response.
Before to post this subject, I already check if this file is in correct location. I also uninstall Quartus Prime Pro 19.4 and install Quartus Prime Pro 21.2 but the same error occurs (the only difference is the folder is update with Quartus Prime Pro 21.2 name)
I notice also than I can not open Platform Designer, maybe these problems are linked because the error 11176 occurs during IP generation for the debug fabric: alt_sld_fab_0 ?
Thanks in advance for your reply,
Vincent
- RichardT_altera
Hi @VFlav
Could you help to share the all error messages found during the Analysis & Synthesis stage?
Please also share the error found during the IP generation in Platform Designer.
Screenshot of the error message will do as well.
If you have a specific design that could duplicate the error, please help to share with us.
Richard Tan
- VFlav
Inexplicably, I can now open Platform Designer and the error has desappear from compilation.
I didn't made any modification, and I can't explain it.
Thanks for your support,
Vincent
