Error(11176): quartus\bin64\ccl_ver_jni_stub.dll: Can't find dependent libraries
Hi @VFlav
Could you check whether the ccl_ver_jni_stub.dll is found in the ...quartus\bin64? I suspect this might be due to bad Quartus installation.
Try to re-install the latest Quartus Pro version 21.2 and check if the issue persists.
You may download it from: https://fpgasoftware.intel.com/21.2/?edition=pro
Richard Tan
Thanks for your response.
Before to post this subject, I already check if this file is in correct location. I also uninstall Quartus Prime Pro 19.4 and install Quartus Prime Pro 21.2 but the same error occurs (the only difference is the folder is update with Quartus Prime Pro 21.2 name)
I notice also than I can not open Platform Designer, maybe these problems are linked because the error 11176 occurs during IP generation for the debug fabric: alt_sld_fab_0 ?
Thanks in advance for your reply,
Vincent
- RichardT_altera5 years ago
Hi @VFlav
Could you help to share the all error messages found during the Analysis & Synthesis stage?
Please also share the error found during the IP generation in Platform Designer.
Screenshot of the error message will do as well.
If you have a specific design that could duplicate the error, please help to share with us.
Richard Tan
- VFlav5 years ago
This error doesn't occur with platform designer but during Analysis & Synthesis stage.
I just notice than I can't open Platform Designer, but I don't know if these problems are linked
Please find behind messages reported during Analysis & Synthesis stage :
-- Quote begin --
Info: Found 210 design entities
Info: There are 453 partitions after elaboration.
Info: Creating instance-specific data models and dissolving soft partitions
Info (18299): Expanding entity and wildcard assignments.
Info (18300): Expanded entity and wildcard assignments. Elapsed time: 00:00:00
Info (11170): Starting IP generation for the debug fabric: alt_sld_fab_0.
Error (11176): C:\intelFPGA_pro\19.4\quartus\bin64\ccl_ver_jni_stub.dll: Can't find dependent libraries
Info (11172): at java.lang.ClassLoader$NativeLibrary.load(Native Method)
Info (11172): at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1934)
Info (11172): at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1817)
Info (11172): at java.lang.Runtime.load0(Runtime.java:809)
Info (11172): at java.lang.System.load(System.java:1086)
Info (11172): at com.altera.version.AlteraProductInfo$1.load(AlteraProductInfo.java:27)
Info (11172): at com.altera.utilities.AltLibraryLoader.doLoad(AltLibraryLoader.java:189)
Info (11172): at com.altera.utilities.AltLibraryLoader.doLoad(AltLibraryLoader.java:146)
Info (11172): at com.altera.utilities.AltLibraryLoader.loadLibraries(AltLibraryLoader.java:109)
Info (11172): at com.altera.version.AlteraProductInfo.<clinit>(AlteraProductInfo.java:31)
Info (11172): at com.altera.infrastructure.common.QuartusPrime.isPro(QuartusPrime.java:58)
Info (11172): at com.altera.qsys.generate.PlatformBuilderDeploy.main(PlatformBuilderDeploy.java:130)
Info (11172): ***************************************************************
Info (11172): Quartus is a registered trademark of Intel Corporation in the
Info (11172): US and other countries. Portions of the Quartus Prime software
Info (11172): Code, and other portions of the code included in this download
Info (11172): Or on this DVD, are licensed to Intel Corporation and are the
Info (11172): Copyrighted property of third parties. For license details,
Info (11172): Refer to the End User License Agreement at
Info (11172): Http://fpgasoftware.intel.com/eula.
Info (11172): at com.altera.qsys.generate.QsysGenerate.setUpQsysGenerate(QsysGenerate.java:310)
Info (11172): at com.altera.qsys.generate.QsysGenerate.main(QsysGenerate.java:267)
Info (11171): Finished IP generation for the debug fabric: alt_sld_fab_0.
Error (19882): Automatic debug logic insertion has failed.
Error: Flow failed:
Info (144001): Generated suppressed messages file D:/Quartus_designs/V020/output_files/CF3N.syn.smsg
Error: Quartus Prime Synthesis was unsuccessful. 6 errors, 32 warnings-- Quote End --
Thanks for your help,
Vincent
