18 years ago
Error: WYSIWYG I/O
I get the following error when I run Quartus on my design. I know I have seen it before but cannot remember how to fix it. Your help will be greatly appreciated.
Error: WYSIWYG I/O primitive "qdrii:u_qdr|qdr:auk_qdrii_mw_wrapper|qdr_auk_qdrii_sram:qdr_auk_qdrii_sram_inst|qdr_auk_qdrii_sram_datapath:auk_qdrii_sram_datapath|qdr_auk_qdrii_sram_capture_group_wrapper:auk_qdrii_sram_capture_group_wrapper|qdr_auk_qdrii_sram_cq_cqn_group:auk_qdrii_sram_cq_cqn_group|cqn_inst" is not properly connected to a top level pin
    Are you using a third-party synthesis tool? If so, this is probably one of the cases where you have to tell the tool not to put an I/O cell ATOM between the port of the black box where you instantiated the memory interface IP and the top-level port corresponding to the device pin. If the IP has the I/O cell ATOM ("WYSIWYG I/O primitive" in your message), then the third-party tool needs to connect it up the hierarchy to the device pin with a simple wire connection in the .edf or .vqm file.
    If you are using Quartus integrated synthesis, maybe you have some logic between the I/O cell ATOM in the IP and the device pin. Or maybe you just failed to make the connection in the RTL.
    If you are using Synplify pro,
    tell quartus in the EDA tool preference that the entry tool is synplify pro.
    @ shempington
    could you find a solution for that?
    I am also getting the same error.
