16 years agoError with the DDR SDRAM generated
I am using DDR SDRAM controller in SOPC builder, when compiling the project with QuartusII following error appears. My FPGA is EP2S60F672C3.
Any help on how to resolve this. Error: Atom "ddr_dqs_to_and_from_the_ddr_sdram[1]" has port DQSUPDATEEN that must be connected to the dqsupdate output of a DLL because the dqs_ctrl_latches_enable parameter is set to true Error: Atom "ddr_dqs_to_and_from_the_ddr_sdram[0]" has port DQSUPDATEEN that must be connected to the dqsupdate output of a DLL because the dqs_ctrl_latches_enable parameter is set to true Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 200 warnings Info: Allocated 218 megabytes of memory during processing Error: Processing ended: Sun Nov 29 15:27:00 2009 Error: Elapsed time: 00:01:13 Thanks , hquanlin
