15 years ago
Error with operators
Everytime i try to use an operator (+, -,...), I have the following error:
Error(10327) - can't determine definition of operator "-", found 0 possible definitions.
Here is the full code, but the problem is at the bold part.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
use ieee.numeric_std.all;
ENTITY reg_b IS
PORT ( clk, dec: IN STD_LOGIC;
D: IN STD_LOGIC_VECTOR(3 downto 0);
B: OUT STD_LOGIC);
END reg_b;
ARCHITECTURE comportamento OF reg_b IS
signal Q: std_logic_vector(3 downto 0);
signal Q_integ: integer range 0 to 15;
BEGIN
PROCESS (clk)
BEGIN
IF clk'EVENT AND clk = '1' THEN
Q<=D;
END IF;
END PROCESS;
Q_integ <= to_integer(unsigned(Q));
Process(dec)
Begin
If dec'event AND dec='1' Then
q_integ <= q_integ - '1';
IF Q='0' Then B<='1';
End IF;
END IF;
End Process;
END comportamento;
I appreciate some help.
Thank you.
    Several problems here.
    For a start, you cannot assing Q_integ from a process and outside the process. You can only assign it in one place.
    secondly try
    Q_integ <= Q_integ - 1; --instead of '1'
    But in simulation you're going to get an error when it tries to go below 0.
    So, change the definition of Q_integ to
    signal Q_integ : unsigned(3 downto 0);
    But you're going to see 'XXXX' when you try and simulate it unless you do what I said for the first problem.
    OK, the subtract operator works now, thank you.
    But if I can't assign a value to a variable in both places, or in two process, how can I make a VHDL software that do: When I activate one input, I take an input vector value and save in a variable, and each time I activate input B, i decrement that variable by 1.
    Here is what I did, but i have an error saying Q_int depends on multiple clocks.
    i/o:
    signals:
    signal Q_int: integer range 0 to 15;
    PROCESS (clk, dec)
    BEGIN
    Q<=D;
    Q_int <= to_integer(unsigned(Q));
    END IF;
    Q_int<=Q_int-1;
    END IF;
    END PROCESS;
    Thank You!
    You need to be careful what you say.
    A signal (like Q_int) is not a variable. It is not updated until a process suspends.
    A variable in VHDL is updated immediatly, like a C variable.
    VHDL is not a programming language. its a description language. This is a very important difference.
