OK, the subtract operator works now, thank you.
But if I can't assign a value to a variable in both places, or in two process, how can I make a VHDL software that do: When I activate one input, I take an input vector value and save in a variable, and each time I activate input B, i decrement that variable by 1.
Here is what I did, but i have an error saying Q_int depends on multiple clocks.
i/o:
clk, dec: IN STD_LOGIC;
D: IN STD_LOGIC_VECTOR(3 downto 0);
signals:
signal Q: std_logic_vector(3 downto 0);
signal Q_int: integer range 0 to 15;
PROCESS (clk, dec)
BEGIN
IF clk'EVENT AND clk = '1' THEN
Q<=D;
Q_int <= to_integer(unsigned(Q));
END IF;
If dec'event AND dec='1' Then
Q_int<=Q_int-1;
END IF;
END PROCESS;
Thank You!
