11 years ago --- Quote Start --- You specify the language for the output entity when you generate the core. Not in the project settings. The LPM_counter.tdf.txt you posted doesnt seem to be a megawizard file? where did you get it from? it looks like library code to me - that shouldnt be included in your project. From the looks of it, offline is the component you generated. --- Quote End --- The file: LPM_counter.tdf.txt is not "included" in my project by me, it is where I am pointed, if I double click the error in the message window:
Error (287127): Text Design File syntax error: Text Design File contains '(' where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected So yes, this looks like a library file, but why do I get an error which points here? (Could there be a fault in the implementation of the LPM counter?).
