11 years ago --- Quote Start --- Yes - but when you generate the counter - you have the choice of which language to generate it in. Why did you chose AHDL, rather than VHDL? --- Quote End --- I have not specifically chosen it to be an AHDL LPM component. (can't see how to chose between the two). Project settings are set to use VHDL IP settings. Project settings -> IP settings -> "IP generation HDL preference:" VHDL.
