16 years ago --- Quote Start --- Also I tried running the hello world program from the NIOS 2 IDE 9.1, but it threw error like the one below. --- Quote End --- This usually happens when you are using a time limited OpenCorePlus IP (in this case NIOS 2). After you configure fpga with usb blaster, don't close the message box, otherwise the usb programmer will disconnect and the ip core will be disabled. Cris
