17 years agoFrom what you describe it looks as if in this instance modelsim does not like the 'high attribute being applied to anything but a type or subtype. Maybe this is related to the fact that it is applied to a port whose length is specified by a generic
Without looking at the LRM I do not know whether this is an issue with modelsim or Quartus A work around would be to change the code as follows: subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0); type memory_t is array((2**ADDR_WIDTH) - 1 downto 0) of word_t; -- Declare the RAM signal. signal ram : memory_t; -- Register to hold the address signal addr_reg : natural range 0 to (2**ADDR_WIDTH) - 1; i.e. use the generic to control the "high" value of address Hope this helps
