17 years ago
Error while running simulation
I was just checking out the design template for "Single port RAM" which was provided in Quartus II 8.0. The model compiles in Quartus II but gives me an error in ModelSim AE 6.1g.
here is the template:
-- Quartus II VHDL Template
-- Single port RAM with single read/write address
library ieee;
use ieee.std_logic_1164.all;
entity ram_2 is
generic
DATA_WIDTH : natural := 8;
ADDR_WIDTH : natural := 3
port
clk : in std_logic;
addr : in natural range 0 to (2**ADDR_WIDTH) - 1;
data : in std_logic_vector((DATA_WIDTH-1) downto 0);
we : in std_logic := '1';
q : out std_logic_vector((DATA_WIDTH -1) downto 0)
end entity;
architecture rtl of ram_2 is
-- Build a 2-D array type for the RAM
subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0);
type memory_t is array(addr'high downto 0) of word_t;
-- Declare the RAM signal.
signal ram : memory_t;
-- Register to hold the address
signal addr_reg : natural range 0 to addr'high;
begin
process(clk)
begin
if(rising_edge(clk)) then
if(we = '1') then
ram(addr) <= data;
end if;
-- Register the address for reading
addr_reg <= addr;
end if;
end process;
q <= ram(addr_reg);
end rtl;
and here is the error :
"# ** Error: C:/altera/80/quartus/Test/RAM_Tst_1/ram_2.vhd(30): Prefix (signal "addr") for attribute "high" is not a type mark.# ** Error: C:/altera/80/quartus/Test/RAM_Tst_1/ram_2.vhd(36): Prefix (signal "addr") for attribute "high" is not a type mark.# ** Error: C:/altera/80/quartus/Test/RAM_Tst_1/ram_2.vhd(54): VHDL Compiler exiting# ** Error: C:/altera/80/modelsim_ae/win32aloem/vcom failed.
Please Advice...
    From what you describe it looks as if in this instance modelsim does not like the 'high attribute being applied to anything but a type or subtype. Maybe this is related to the fact that it is applied to a port whose length is specified by a generic
    Without looking at the LRM I do not know whether this is an issue with modelsim or Quartus
    A work around would be to change the code as follows:
    type memory_t is array((2**ADDR_WIDTH) - 1 downto 0) of word_t;
    signal addr_reg : natural range 0 to (2**ADDR_WIDTH) - 1;
    i.e. use the generic to control the "high" value of address
    Hope this helps
