is1135
2 years agoError while installing quartus 23.1std
While trying to install Quartus 23.1std I get the following error message: $./QuartusSetup-23.1std.0.991-linux.run* local variable is temporary but should be an argument Aborted (core dumped) The...
TingJiangT_Intel
Contributor
2 years agoNot really sure what happens. Maybe there are some libraries needed, you can check this first.
"ldd QuartusSetup-23.1std.0.991-linux.run"
And make sure you have permission to execute the file, and you have access to the installation path.
