Error: (vsim-3033): Instantiation of 'cycloneii_asmiblock' failed. The design unit was not found.
Problem background:
I'm using a Cyclone 4 FPGA (EP4CE40 series FPGA). I used the MegaWizard to create the ALTASMI_PARALLEL component. I want to use this so I can program the EPCS4 serial memory from my external Flash.
I need to simulate my logic that is used to write data in and out to the ASMI block. The logic synthesizes correctly, but when I send it out to Modelsim (Directly call Modelsim from Quartus for simulation)to see how it works I get the following error(As shown in the following figure):
** Error: (vsim-3033) C:/altera_designs/fpga_factory_config/asmi.v(330): Instantiation of 'cycloneii_asmiblock' failed. The design unit was not found.
The screenshot of the engineering file in Quartus is as follows
The Modelsim simulation configuration file is as follows:
So what is missing? Where can I find cycloneii_asmiblock? How should I configure it?
Thank you!
- RichardT_altera
Have you try to simulate using the Nativelink feature to automatically compile your design, Altere IP, simulation model libraries and testbench?
Questa* Intel® FPGA Edition Quick-Start: Intel® Quartus® Prime Standard Edition:
https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/simulation-quick-start.html
Richard Tan
- RichardT_altera
Any update on this?
Richard Tan
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Richard Tan
