asard5
6 years agoERROR: Unable to checkout a license. Vsim is closing.
I am trying to run a VWF and I get this error: **** Running the ModelSim simulation **** c:/intelfpga_lite/19.1/modelsim_ae/win32aloem//vsim -c -do lab1_ex.do Unable to checkout a license. Vsim ...
KhaiChein_Y_Intel
6 years agoHi,
Can you check if you are installing the Starter edition? The path indicates that you are using the paid edition of the software -- modelsim_ae. The starter edition is modelsim_ase.
KhaiY
- NIKO_5K2 years ago
Hola,
tengo el mismo problema pero en majaro linux, el mensaje que arroja es este:
Unable to find the license file. It appears that your license file environment variable (e.g., LM_LICENSE_FILE) is not
set correctly.
** Error: Invalid license environment. Application closing.
