Altera_ForumHonored Contributor12 years agoError: Top-level design entity "bai3" is undefined Can You help me correct this problem in this code below: module PWM( Ton,T,clk,Output_PWM); input clk; output Output_PWM; input [7:0] Ton; input [7:0] T; reg Output_PWM; integer ...Show More
Altera_ForumHonored Contributor12 years agoadd "bai3.v" to project and check if module name is bai3.v
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
