17 years ago --- Quote Start --- Usually you don't want a bulk virtual pin assignment, i.e. clocks are real, perhaps a global reset, etc. --- Quote End --- Even if the clock input to this part of the design is not a real device pin (for example, it's driven by a PLL in the top level of the design), don't use a virtual-pin assignment for it. The Quartus handbook says not to use virtual pins for clocks. There are a few more cases too that don't support virtual pins. From Volume 2, Section III, Chapter 10: --- Quote Start --- Bidirectional, registered I/O pins, and I/O pins with output enable signals cannot be virtual pins. ... Use the following guidelines for creating virtual pins in the Quartus II software:
- Do not declare clock pins
- Nodes or signals that drive physical device pins in the top-level design should not be declared as virtual pins
