10 years agoError reading masterData.xml
I am using the 64 bit version of Quartus 13.0.1 (the last version that supports my device) under Widows 7 with IE11. When I try to use Quartus Help, I get an error "Error reading masterData.xml" and the search function doesn't work etc. Can anyone help please? regards Dave10 Replies
** BUMP **
Can anyone offer any advice on this one please ? regards Dave - Altera_Forum
Try using Chrome or Firefox to open the Quartus II help.
After installing it, Chrome doesn't even open the help file
file:///C:/altera/13.0sp1/quartus/common/help/webhelp/master.htm#mergedProjects/quartus/gl_quartus_welcome.htm The Chrome "X"/"circle" just toggles - Altera_Forum
I met the same problem and found a way.
Download an old version Firefox and try. I find a 3.0.2 version Firefox and works well in WIN7. IE 8.0 in WinXP is also OK. - Altera_Forum
thanks a lot for the feedback. I may give it a try, but surely there must be a way to get this to work with IE without resorting to trying different browsers? Does anyone from Altera monitor these forums? If I am not the only person that has a problem with Quartus Help and IE, then surely there must be a known solution? I have not been able to find any knowledge base articles etc. on the subject regards Dave - Altera_Forum
You only can find at altera site "We know about problem", btw local Quartus 15.1 Help works fine in my Firefox 42. for 15.0 i had to use IE.
I think Altera software developement team put attention on new product-line more. - Altera_Forum
Unfortunately, (as I mentioned previously) V13 is the latest version that I can use.
I didn't even find "We know about problem" on the Altera site. I am not surprised that Altera would not put resources into fixing a (potential) issue in Release 13, but I would have hoped that they might be able to offer advice if this was/is a known problem with Quartus - Altera_Forum
When I surfed the altera site 6 monthes ago for your question it was.
You always can use online resource from http://quartushelp.altera.com but useful information stored in pdf and you can download them separately. check also http://www.altera.com/support/support-resources.html I am not sure if this trick can be applied what file should be borrowed from Quartus Prime (15.1) Help that allow launch of your local Quartus II 13 Help <- Perhaps all helpfiles . it is not included in standard installation package and can be used without quartus. - Altera_Forum
I think that I know what the problem is -
It seems that Quartus Help is built using RoboHelp, and the Adobe site shows :- https://helpx.adobe.com/robohelp/kb/webhelp-issues-robohelp-versions-10.html NB : The article describes my problem and also notes the Chrome issue that I saw when I installed it - the "try Chrome" advice couldn't help But I can't fix it, as I don't know how to (or even whether you can) rebuild the Quartus Help files :-( - ChinTe
Firefox 52.9.0 ESR 32/64bit in Win10 is also OK.
Mozilla Firefox 52.9.0 installation directory can be named otherwise.
EX:
Web Browser: C:\Program Files\Mozilla Firefox 52.9\firefox.exe
