10 years agoError reading masterData.xml
Hi, I am using the 64 bit version of Quartus 13.0.1 (the last version that supports my device) under Widows 7 with IE11. When I try to use Quartus Help, I get an error "Error reading maste...
10 years agoWhen I surfed the altera site 6 monthes ago for your question it was.
You always can use online resource from http://quartushelp.altera.com but useful information stored in pdf and you can download them separately. check also http://www.altera.com/support/support-resources.html I am not sure if this trick can be applied what file should be borrowed from Quartus Prime (15.1) Help that allow launch of your local Quartus II 13 Help <- Perhaps all helpfiles . it is not included in standard installation package and can be used without quartus.
