Error: No spd files are included in quartus project
- 5 years ago
Hi @syam404
May I know does my latest reply help?
Do you have further questions in regards to this case?
Richard Tan
Good Morning Sir,
I am using Modelsim Intel FPGA Starter Edition only. In quartus prime 21.2 there is no RTL simulator like any other versions, so I have only one option to simulate that is by generating ip setup simulation script while doing this after compilation I am getting error like
How could I remove this error please help me @RichardTanSY_Altera
I have already referred the below UG still my problem not solved. And many other UGs and Intel FPGA videos I saw.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20093.pdf
Syam Sundar( [email protected])
Hi @syam404
Your design only consist an adder, you don't need to use the Generate Simulator Setup Script for IP unless your design using Intel IP.
You can just open a new project in Modelsim Intel FPGA Starter Edition and simulate the design.
You may refer to this webpage on the how-to run manually simulation in Modelsim Intel Edition:
Could you explain what you meant by?
"In quartus prime 21.2 there is no RTL simulator like any other versions."
Quartus Prime software is not a RTL simulator though. We will need a third-party simulator tool for functional simulation.
Please refer to this brochure for further information:
Richard Tan
- RichardT_altera5 years ago
Hi @syam404
Richard Tan
