15 years agoI found similar issues in two cases:
1) using legacy symbols from maxplus2 directory 2) trying to simulate designs including LPM_* symbols moving from QII9.1 to 10.1 In both cases a workaround was to eliminate the bdf from the project and just synthesize and simulate the HDL files Fpr the case 1) also a slight change of the HDL files has been needed. Hope it helps.
