15 years agoI have a similar issue with Quartus V9.0sp2.
Although I've not verified it, I thought of this possible cause: When I create a new symbol in a design, then I can always open with hierarchy. If I copy and add the module files to another project, then hierarchy is not recognized, although compilation always succeeds, as in your case. I can reactivate hierarchy if I force a create symbol. My supposition is that the hierarchy information is stored in the project file or in project library when I create the symbol, so it is lost if you simply copy .bdf .qip. .vhd .v files and add them to the other project.
