8 years agoError in library module cyclonev_atoms_ncrypt
I am attempting to run a simulation with design components from QSYS. I am running the msim_setup.tcl script provided by QSYS and am getting the following error message... # vsim -t ps -L ...
8 years agoAfter using the suppress option, the simulation gets to this and fails....
# Loading altera_mf_ver.altera_std_synchronizer_bundle # ** Error: (vsim-3033) Instantiation of '<protected><protected><protected><protected><protected><protected>' failed. The design unit was not found. # Time: 0 ps Iteration: 0 Protected: /C5G_QSYS/epcq_controller_0/asmi_parallel_inst/altera_asmi_parallel/sd4/inst/<protected> File: C:/bin/altera/17.0.1/quartus/eda/sim_lib/mentor/cyclonev_atoms_ncrypt.v Line: UNKNOWN- ozberk1 year ago
I've got same error from Questa Sim. Could you explain the solution one more time?
Best Regards.
