8 years agoError in library module cyclonev_atoms_ncrypt
I am attempting to run a simulation with design components from QSYS. I am running the msim_setup.tcl script provided by QSYS and am getting the following error message... # vsim -t ps -L ...
8 years agoHere is the result from running with -novopt....
# vsim -novopt -t ps -L work -L work_lib -L error_adapter_0 -L altera_epcq_controller_core -L altera_asmi_parallel -L rsp_mux -L cmd_mux -L cmd_demux -L router_001 -L router -L avalon_st_adapter -L crosser -L rsp_mux_002 -L rsp_mux_001 -L rsp_demux_011 -L rsp_demux_009 -L rsp_demux_005 -L rsp_demux_004 -L rsp_demux_002 -L rsp_demux -L cmd_mux_002 -L cmd_demux_002 -L cmd_demux_001 -L epcq_controller_0_avl_mem_burst_adapter -L nios2_qsys_data_master_limiter -L router_014 -L router_007 -L router_005 -L router_003 -L router_002 -L avalon_internal_bram_interface_avalon_slave_agent -L nios2_qsys_data_master_agent -L avalon_internal_bram_interface_avalon_slave_translator -L nios2_qsys_data_master_translator -L remote_update_controller -L remote_update_core -L cpu -L dll0 -L oct0 -L c0 -L s0 -L p0 -L pll0 -L p2b_adapter -L b2p_adapter -L transacto -L p2b -L b2p -L fifo -L timing_adt -L jtag_phy_embedded_in_jtag_master -L rst_controller -L irq_synchronizer -L irq_mapper -L mm_interconnect_1 -L mm_interconnect_0 -L sysid_qsys -L sysclk_timer -L remote_update_0 -L onchip_mem -L nios2_qsys -L mem_if_lpddr2_emif -L mddr_to_mm_bridge_0 -L jtag_to_avalon_master -L hw_git_hash -L ext_int -L epcq_controller_0 -L avalon_internal_bram_interface -L avalon_external_interface_0 -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclonev_ver -L cyclonev_hssi_ver -L cyclonev_pcie_hip_ver C5G_QSYS # Start time: 15:55:58 on Jun 21,2018 # ** Error (suppressible): (vsim-12110) All optimizations are disabled because the -novopt option is in effect. This will cause your simulation to run very slowly. If you are using this switch to preserve visibility for Debug or PLI features, please see the User's Manual section on Preserving Object Visibility with vopt. -novopt option is now deprecated and will be removed in future releases. # Error loading design # Error: Error loading design # Pausing macro execution Note that I am simply attempting to run the msim_setup.tcl generated by QSYS.
