Shainy
5 years agoError Generated when creating a new project on Nios II- Eclipse
whenever I try to create a project on Nios II-Eclipse through File> New> Nios II Application and BSP from Template, I get the following error:
Failed to execute: wsl dos2unix create-this-bsp;...
BoonBengT_Altera
Moderator
5 years agoHi @Shainy,
Thank you for posting in Intel community forum and hope all is well.
Suspecting that the issues might be related to missing WSL, moving forward for quartus 19.1 the WSL is required for Nios EDS.
If WSL is not being installed, would recommend to do so and you can find the instruction here.
Please do let us know if that helps to clarify your doubts.
Best Wishes
BB
- Shainy5 years ago
Hi @BoonBengT_Altera ,
Thank you so much for your reply, and hope all is well with you as well.
I'll download WSL and move ahead. and, yes, this did clarify my doubts. Thanks again!
Best Wishes,
Shainy
