16 years agoError Fatal Quartus II
Hi, i would like help, because i don't know where is problem in my code.
The quartus show me this: *** fatal error: access violation at 0x0498c728 module: quartus_map.exe stack trace: 0x1c728 : sutil_reset_aux_values + 0x28 (synth_sutil) end-trace when i comment the lines in the last case (When Cheio), the problem is solved, but wasn't possible to finish the program, because i can't move the value to Disp1 and Disp2. Lines: disp1 <= "10001110"; -- display 1 condicao de hi - 142 disp2 <= "00111000"; -- display 2 condicao de hi - 56 my code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity Boia is
port
( clk : in std_logic;
Lo : in std_logic;
Hi : in std_logic;
Fu : in std_logic;
Beep : out std_logic;
Disp1 : out std_logic_vector (7 downto 0);
Disp2 : out std_logic_vector (7 downto 0));
end Boia;
architecture Funcao of Boia is
signal dis1 : std_logic_vector (7 downto 0) := "00000000";
signal dis2 : std_logic_vector (7 downto 0) := "00000000";
signal chave: std_logic;
signal flag : std_logic;
type Sens is (Baixo, Alto, Cheio);
signal Estado : Sens := Baixo;
begin
process
begin
wait until clk'event and clk ='1';
CASE Estado is
when Baixo =>
chave <= Lo;
if chave = '0' then
Disp1 <= "11111100"; -- DISPLAY 1 CONDICAO DE LO - 252
Disp2 <= "11001110"; -- DISPLAY 2 CONDICAO DE LO - 206
flag <= '1';
else
Disp1 <= "00011100"; -- DISPLAY 1 CONDICAO DE OP - 28
Disp2 <= "00111010"; -- DISPLAY 2 CONDICAO DE OP - 58
flag <= '1';
end if;
Beep <= not flag;
Estado <= Alto; -- PROXIMO ESTADO
when Alto =>
chave <= Hi;
if chave = '1' then
Disp1 <= "01101110"; -- DISPLAY 1 CONDICAO DE Hi - 110
Disp2 <= "00001000"; -- DISPLAY 2 CONDICAO DE Hi - 8
Beep <= not flag;
end if;
Estado <= Cheio; -- PROXIMO ESTADO
when Cheio =>
chave <= Fu;
if chave = '1' then
Disp1 <= "10001110"; -- DISPLAY 1 CONDICAO DE Hi - 142
Disp2 <= "00111000"; -- DISPLAY 2 CONDICAO DE Hi - 56
Beep <= not flag;
end if;
Estado <= Baixo; -- PROXIMO ESTADO
END CASE;
end process;
end Funcao;
