jyun_criticallink
3 years agoError during QSYS Generation: sequencer/sequencer.elf not found (Ubuntu 20.04)
I am currently in the process of porting an existing project from Quartus Prime 18.1 to Quartus Prime 22.1. The Platform designer was able to upgrade all the existing IP to version 22.1. Ho...
jyun_criticallink
3 years agoHello,
Thank you for responding to the issue promptly.
I've tried your instructions and here are the results:
I have verified that all the requisite software is installed and running, specifically the i386 versions of everything.
I made a minimal example of the only the DDR3 SDRAM IP as shown in the attachment, and it results in the exact same error as posted above.
It however did work in Intel Quartus 21.1, with the full project generation, and there was no problem generating the sequencer.
Would this then be a problem exclusive to 22.1, and is there any resolution to this problem?
With Regards,
Joshua Yun
