jyun_criticallink
3 years agoError during QSYS Generation: sequencer/sequencer.elf not found (Ubuntu 20.04)
I am currently in the process of porting an existing project from Quartus Prime 18.1 to Quartus Prime 22.1. The Platform designer was able to upgrade all the existing IP to version 22.1. Ho...
AdzimZM_Altera
3 years agoHi Joshua Yun,
If you generate only the DDR3 UniPHY SDRAM IP, do you see similar issue?
Can you check the software requirement in Table 1 in the link below?
If you have done that and the issue still exist, I would like you try on Quartus Prime Standard Edition version 21.1 if possible.
Adzim
