15 years agoError: Can't place differential I/O negative pin mem_dqs[0] at a differential I/O pos
When I compile my own DDR3 ctrl, the errors show like below:
error: can't place differential i/o negative pin mem_dqs[0] at a differential i/o positive location d29(pad_1046)error: can't place differential i/o negative pin mem_dqs[1] at a differential i/o positive location c31(pad_1058)
error: can't place differential i/o negative pin mem_dqs[2] at a differential i/o positive location b34(pad_1070)
error: can't place differential i/o negative pin mem_dqs[3] at a differential i/o positive location e33(pad_1082)
error: can't place differential i/o positive pin mem_dqsn[0] at a differential i/o negative location c29(pad_1047)
error: can't place differential i/o positive pin mem_dqsn[1] at a differential i/o negative location b31(pad_1059)
error: can't place differential i/o positive pin mem_dqsn[2] at a differential i/o negative location a34(pad_1071)
error: can't place differential i/o positive pin mem_dqsn[3] at a differential i/o negative location d33(pad_1083) In fact, i use the script below to tell quartus that mem_dqs[0] is the positive pin, but quartus still infers as a negative pin. set_instance_assignment -name dqsb_dqs_pair on -from mem_dqns[0] -to mem_dqs[0] Could someone help me?
