11 years ago
Error at Analysis and Synthesis step in Quartus 14.1 - (generic_pll primitive )
when i am running my design in quartus 14.1 it is throwing error as -
Error (129037): Output port OUTCLK on atom "vip_example:sys|vip_example_mem_if_ddr3_emif_0:mem_if_ddr3_emif_0|vip_example_mem_if_ddr3_emif_0_pll0ll0|pll2_phy", which is a generic_pll primitive, is driving one or more illegal destinations
Error (129026): Output port OUTCLK of atom "vip_example:sys|vip_example_mem_if_ddr3_emif_0:mem_if_ddr3_emif_0|vip_example_mem_if_ddr3_emif_0_pll0ll0|pll2_phy" is driving the I input port of atom "ddr3_emif_0_pll_sharing_pll_mem_phy_clk~output", which is a cyclonev_io_obuf primitive. This connection is illegal
Info (129038): Input port INCLK of a cyclonev_phy_clkbuf primitive is a valid destination for output port OUTCLK on atom "vip_example:sys|vip_example_mem_if_ddr3_emif_0:mem_if_ddr3_emif_0|vip_example_mem_if_ddr3_emif_0_pll0ll0|pll2_phy"
Info (129038): Input port CLK of a cyclonev_ff primitive is a valid destination for output port OUTCLK on atom "vip_example:sys|vip_example_mem_if_ddr3_emif_0:mem_if_ddr3_emif_0|vip_example_mem_if_ddr3_emif_0_pll0ll0|pll2_phy"
Info (129038): Input port CLK of a cyclonev_dll primitive is a valid destination for output port OUTCLK on atom "vip_example:sys|vip_example_mem_if_ddr3_emif_0:mem_if_ddr3_emif_0|vip_example_mem_if_ddr3_emif_0_pll0ll0|pll2_phy"
Error (130005): When the OUTCLK port of a generic_pll primitive is driving out to the INCLK port of a cyclonev_phy_clkbuf it may not fanout to other destinations
what can be the issue?? i am not able to figure out.
PS - the design gives no issue during compilation when i run the same design on Quartus 13.0.
1 Reply
    I have additionally created a small design and checked that the issue is device independent (in Quartus 14.1).
    As far as i have gone through, the issue is with "ddr3 SDRAM controller with Uniphy". you may check at your end in order to confirm.
