12 years ago
Error about library path of Simulation Waveform Editor
Hello
I am using simulation waveform editor (Altera Quartus II 64-Bit 14.0 Web Edition) to simulate a simple RS latch with verilog as follows.
module rs_latch (Clk, R, S, Q);
input Clk, R, S;
output Q;
wire R_g, S_g, Qa, Qb;
and(R_g, R, Clk);
and(S_g, S, Clk);
nor(Qa, R_g, Qb);
nor(Qb, S_g, Qa);
assign Q = Qa;
endmodule
The input setup of RS latch simulation in simulation waveform editor is as attachment.
And when I use "Run Functional Simulation" or "Run Timing Simulation", it would start to run a series processes, and I would get a error message as follows.
(only list part of error message because of the characters number limitation in this forum.)
Determining the location of the ModelSim executable...
Using: C:\altera\14.0\modelsim_ase\win32aloem
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog rs_latch -c rs_latch --vector_source="D:/FPGA/Lab03/Part1_RSLatch/rs_latch.vwf" --testbench_file="D:/FPGA/Lab03/Part1_RSLatch/simulation/qsim/rs_latch.vwf.vt"
Info: *******************************************************************
Info: Running Quartus II 64-Bit EDA Netlist Writer
Completed successfully.
**** Generating the functional simulation netlist ****
quartus_eda --functional=on --flatten_buses=off --simulation --tool=modelsim_oem --format=verilog --output_directory="D:/FPGA/Lab03/Part1_RSLatch/simulation/qsim/" rs_latch -c rs_latch
**** Generating the ModelSim .do script ****
D:/FPGA/Lab03/Part1_RSLatch/simulation/qsim/rs_latch.do generated.
**** Running the ModelSim simulation ****
C:/altera/14.0/modelsim_ase/win32aloem/vsim -c -do rs_latch.do
Reading C:/altera/14.0/modelsim_ase/tcl/vsim/pref.tcl
# 10.1e
# do rs_latch.do # ** Warning: (vlib-34) Library already exists at "work".# # Model Technology ModelSim ALTERA vlog 10.1e Compiler 2013.06 Jun 12 2013# -- Compiling module rs_latch
# # Top level modules:# rs_latch# Model Technology ModelSim ALTERA vlog 10.1e Compiler 2013.06 Jun 12 2013# -- Compiling module rs_latch_vlg_sample_tst
# -- Compiling module rs_latch_vlg_check_tst
# -- Compiling module rs_latch_vlg_vec_tst# # Top level modules:# rs_latch_vlg_vec_tst
# vsim -L cyclonev_ver -L altera_ver -L altera_mf_ver -L 220model_ver -L sgate_ver -L altera_lnsim_ver -c -voptargs=\"+acc\" -t 1ps -novopt work.rs_latch_vlg_vec_tst # Loading work.rs_latch_vlg_vec_tst# ** Error: (vsim-19) Failed to access library 'cyclonev_ver' at "cyclonev_ver".
# No such file or directory. (errno = ENOENT)
# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".
# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".
# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".
# ** Error: (vsim-19) Failed to access library 'sgate_ver' at "sgate_ver".
# ** Error: (vsim-19) Failed to access library 'altera_lnsim_ver' at "altera_lnsim_ver".
# ** Error: (vsim-3033) rs_latch.vo(76): Instantiation of 'cyclonev_io_obuf' failed. The design unit was not found.
# Region: /rs_latch_vlg_vec_tst/i1
# Searched libraries:
# Loading work.rs_latch_vlg_check_tst
# Error loading design
Error.
By the message, I think when it links to the library, it can not search the correct library path.
I know it links to the library by the "modelsim.ini" in the path "C:\altera\14.0\modelsim_ase\", and part content of "modelsim.ini" is as follows.
altera_mf = $MODEL_TECH/../altera/vhdl/altera_mf
altera = $MODEL_TECH/../altera/vhdl/altera
altera_lnsim = $MODEL_TECH/../altera/vhdl/altera_lnsim
lpm = $MODEL_TECH/../altera/vhdl/220model
220model = $MODEL_TECH/../altera/vhdl/220model
maxii = $MODEL_TECH/../altera/vhdl/maxii
maxv = $MODEL_TECH/../altera/vhdl/maxv
fiftyfivenm = $MODEL_TECH/../altera/vhdl/fiftyfivenm
I have tried all possible setting about the library path, but I still can't solve this problem.
Can someone help me to solve this problem or tell me how can I correctly link simulator to the library path?
Or did I miss some important steps here?
Look forwarding to your help.
Thank you very much!!!!
    Do you solve this problem? I meet this too, how do solve it ?
    The following instructions are for users who have the Mentor Graphics ModelSim DE 10.5c version installed (Note this is NOT the free Altera version).
    The instructions should apply if you have other versions of ModelSim and/or Questa. Also, this was tested with Quartus Prime 16.0 version
    1. Make sure to specify the ModelSim simulator path under "Tools -> Options -> EDA Tools Options"
    2. Compile the simulation library for ModelSim using "Tools -> Launch EDA Simulation Library Compiler" and specify settings...
    3. Copy the "modelsim.ini" file to the "..\simulation\qsim" directory
    4. Add under the "[Library]" section the followings:
    [Library]
    ... blah... blah... blah...
    cyclones_ver = C:/{Path_to_compiled_ModelSim_Simulation_library}/cyclonev_ver
    altera_ver = C:/{same as above}/altera_ver
    ... (add more here)...
    Note that the above paths use "forward" slash (from Windows 10) and not "backward" slash. Also the path is from step 2 above
    Once you do this the simulation will run in the Native Quartus Prime environment. You can also take the *.do file and the test bench and run stand alone in Modelsim outside of Quartus.
    • ZB1's avatar
      ZB1
      This worked for me.
      Thank you,
