Error (210009)
I'm using Quartus II 32 bit Version 11.1. When I try to Change a File, I'm getting the following error
Error (210009) : Device 10M08SCU169 is not supported.
Do I need an updated driver?
Thnks
John
1 Reply
- ZiYingE_Altera
Contributor
Hi JKB,
It is not a driver-related issue. The 10M08SCU169 is a MAX 10 device, which is not supported by Quartus II 11.1. Quartus II 11.1 was released before MAX 10 device support was introduced.
MAX 10 devices are supported starting from:
Quartus II Web Edition 14.0.2/ 14.1
If you choose to use Quartus II v14.0.2, please ensure that Update 2 is installed after the base v14.0 installation:
https://www.altera.com/downloads/fpga-development-tools/quartus-ii-subscription-edition-design-software-version-14-0-b200-windows
However, kindly note that the Quartus II Subscription Edition will required the purchase of the license.
You may also refer to the following page for the latest Quartus software versions that support MAX 10 devices:
https://www.altera.com/design/guidance/software/device-support
At the same time, may I know the Quartus edition you are currently using (e.g., Quartus II Web Edition, Quartus II Subscription Edition, or Quartus Prime Lite/Standard/Pro Edition)?
Feel free to let know if you have any further questions or require assistance.
Thank you.
ZiYingE_Altera
