ERROR 209040:Can't access jtag chain
I need to load the .jic file through the command scripts----quartus_pgm,but the success rate of loading is low,only 10%,and it shows ERROR 209040:can't access jtag chain .But when i load through quartus prime 22.1 software,and it succeeds every time.How does this solve this problem?
quartus_pgm -c USB-Blaster[USB-0] -m jtag -o pvbi;D...
- FakhrulA_altera
Hi yao123,
There's a KDB regarding this issue, you can refer it here if
applicable:
https://www.intel.com/content/www/us/en/support/programmable/articles/000085212.html
Also, have you tried with another USB blaster? Here's also the similar case which you can refer:
Quartus Lite 19.1.0 Linux - Programming Failed - Error (209040): Can't access
Qartus command prompt flashing is unsuccessful throwing "Can't access JTAG chain" error message
Fakhrul
- FakhrulA_altera
As we do not receive any response from you on the previous question/reply/answer that we have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
