yao123
3 years agoERROR 209040:Can't access jtag chain
I need to load the .jic file through the command scripts----quartus_pgm,but the success rate of loading is low,only 10%,and it shows ERROR 209040:can't access jtag chain .But when i load through quar...
FakhrulA_altera
3 years agoHi yao123,
There's a KDB regarding this issue, you can refer it here if
applicable:
https://www.intel.com/content/www/us/en/support/programmable/articles/000085212.html
Also, have you tried with another USB blaster? Here's also the similar case which you can refer:
Quartus Lite 19.1.0 Linux - Programming Failed - Error (209040): Can't access
Qartus command prompt flashing is unsuccessful throwing "Can't access JTAG chain" error message
Fakhrul
