Matan_b
3 years agoError (209014): CONF_DONE pin failed to go high in device 1. during programming encrypted jic file
Hi. I am using Cyclone V device, (with MT25QL256 Flash attached) and I'm trying to implement a secure design that includes encryption with non-volatile key, protection from tampering and protection ...
FakhrulA_altera
3 years agoHi Matan_b,
Have you checked that it is being loaded with an encrypted configuration file? Tamper protection mode prevents the FPGA from being loaded with an unencrypted configuration file. When you enable this mode, the FPGA can only be loaded with a configuration that has been encrypted with your key. Unencrypted configurations and configurations encrypted with the wrong key result in a configuration failure.
Also, before programming the non-volatile key into the devices, ensure that you can successfully configure the FPGA with an unencrypted configuration file.
Fakhrul
