9 years agoError (18994): configuration scheme "passive serial" is not valid for the device
I'm trying to synthesize a System Verilog RTL design to a Stratix 10 device using quartus II v.17 but keep getting the following error. Info (12627): Pin ~ALTERA_MSEL0~ is reserved at location AY8
Info (12627): Pin ~ALTERA_MSEL1~ is reserved at location AY13 Info (12627): Pin ~ALTERA_MSEL2~ is reserved at location AR14 Error (18994): configuration scheme "passive serial" is not valid for the device All my top-level ports have been assigned VIRTUAL_PIN ON as this is just a small part of a larger design and I just want to see if it synthesizes. The error occurs for all Stratix 10 devices. The MSEL# pin locations vary per device. What is causing the error and how do I fix it? How do I tell Quartus II not to use "Passive Serial"? Thank you.2 Replies
go to Asigments-> Device -> Device and Pin options -> Configuration to change configuration mode. Also you can try to play with settings in Asigments-> Device -> Device and Pin options -> Dual-Purpose Pins section - Altera_Forum
Thank you!!
This fixed the problem. --- Quote Start --- Hi, go to Asigments-> Device -> Device and Pin options -> Configuration to change configuration mode. Also you can try to play with settings in Asigments-> Device -> Device and Pin options -> Dual-Purpose Pins section --- Quote End ---
