9 years agoError (18994): configuration scheme "passive serial" is not valid for the device
I'm trying to synthesize a System Verilog RTL design to a Stratix 10 device using quartus II v.17 but keep getting the following error. Info (12627): Pin ~ALTERA_MSEL0~ is reserved at location AY8...
9 years agoHi,
go to Asigments-> Device -> Device and Pin options -> Configuration to change configuration mode. Also you can try to play with settings in Asigments-> Device -> Device and Pin options -> Dual-Purpose Pins section
