Error (175005): Could not find a location with: IO_FUNCTION of GPIO (1 location affected)
I am using Stratix10 1SD280PT2F55E2VGS1
And assign the refclk pin to:
set_location_assignment PIN_AT44 -to "pcie_refclk0(n)"
set_location_assignment PIN_AT45 -to pcie_refclk0
set_location_assignment PIN_AP44 -to "pcie_refclk1(n)"
set_location_assignment PIN_AP45 -to pcie_refclk1
But when fitting, I saw such error:
Error (175020): The Fitter cannot place logic pin in region (3,
Info (14596): Information about the failing component(s):
Info (175028): The pin name(s): pcie_refclk0
Error (16234): No legal location could be found out of 1 considered location(s). Reasons why each location could not be used are summarized below:
Info (175029): pin containing PIN_AT45
Info (175015): The I/O pad pcie_refclk0 is constrained to the location PIN_AT45 due to: User Location Constraints (PIN_AT45) File: XXX.sv Line: 244
Info (14709): The constrained I/O pad is contained within this pin
Error (15307): Cannot apply project assignments to the design due to illegal or conflicting assignments. Refer to the other messages for corrective action.
Error (16297): An error has occurred while trying to initialize the plan stage.
Error: Quartus Prime Fitter was unsuccessful. 6 errors, 2 warnings
Do you have any ideas about this issue?
- AminT_Intel
I am sorry that you are facing this problem. I will try my best to help you.
I believe these fitter errors are due to the invalid reconfiguration clock pin location assignments in the Intel Stratix 10 Hard IP for PCI Express MX H-Tile ES1 FPGA Devkit Design Example. Please go through this workaround: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ip/2018/error-175020---the-fitter-cannot-place-logic-pin-that-is-part-of.html
Thank you.
- AminT_Intel
Is all of your questions addressed? I will close this case in 3 days if there is no response from you.
