Jiayi_H_Intel
5 years agoError (175005): Could not find a location with: IO_FUNCTION of GPIO (1 location affected)
I am using Stratix10 1SD280PT2F55E2VGS1
And assign the refclk pin to:
set_location_assignment PIN_AT44 -to "pcie_refclk0(n)" set_location_assignment PIN_AT45 -to pcie_refclk0 set_location...
AminT_Intel
5 years agoHello,
I am sorry that you are facing this problem. I will try my best to help you.
I believe these fitter errors are due to the invalid reconfiguration clock pin location assignments in the Intel Stratix 10 Hard IP for PCI Express MX H-Tile ES1 FPGA Devkit Design Example. Please go through this workaround: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ip/2018/error-175020---the-fitter-cannot-place-logic-pin-that-is-part-of.html
Thank you.
AminT_Intel
5 years agoHello,
Is all of your questions addressed? I will close this case in 3 days if there is no response from you.
