16 years ago
Error (10822): HDL error at XXX: couldn't implement registers for assignments
hello everyone
i am having problems with this peice of code
process (clk)
begin
if rising_edge (clk)
then
en<='1';
else en<='0';
end if;
end process;
i have read about thuse errors on the web and saw that the problem is that i cant change the register on both rising edge and falling adge (that would be the ELSE)
but i cant find another way to get the output needed without it.
someone has an idea?
Pini
    There is no "else" for a register, it only changes its value at the rising_edge of clock (or on an asynchronous reset)!
    You should have an signal that is fed by logic (also known as "cloud") that is stored in a register at rising_edge(clk).
    Actually your register is only '1' for one delta cylce in which we have a rising_edge else it is '0'. In other words it is always '0'.
    you can actually (theoretically) change registers on falling_edge(clk) too, but I don't know what it synthizes:
    if rising_edge(clk) or falling_edge(clk)
    endif;
    I recommend reading VHDL tutorials and lecture notes.
    But go ahead, it's fun!
    Thanks for your fast answer, It helped.
    i managed to keep the system working with a square signal instead of those deltas, and now qurtus is ok.
    have a good day
    Pini Sberro
