13 years ago
Error (10822): couldn't implement registers for assignments on this clock edge
Hi people,
Can you please help me out with the following problem:
I try to increment a signal from the state machine at the rising edge of the clock but it gives me the error: Error (10822): HDL error at Deserializer.vhd(131): couldn't implement registers for assignments on this clock edge
Here is the code:
library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Deserializer is
  port(
			   reset, serialin, clk, enable : in std_logic;
				bustofft,sink_imag : out std_logic_vector(11 downto 0);
				led1, led2, clkadc,cs : out std_logic
end entity;
architecture implementation of Deserializer is
--component flip_flop is
--port (
--			clk, reset,enable : in std_logic;
--			countink : in integer range 0 to 99;
--			countoutk : out integer range 0 to 99
--end component;
-- Signals & Variables --
 signal cyclecounter : integer range 0 to 15:=0;
 signal done			: std_logic;
 signal internalbus	: std_logic_vector(11 downto 0);
-- state definitions and signals ----------------------------------
	type state is (
          		Idle,
					Startadc,
					Listen,
					Talk
			signal present_state, next_state: state;
--PORTMAPS------------------------------------------------------------
begin
-- sequential part of the statemachine ----------------------------
	process(reset, clk, next_state)
	begin
	if (reset = '1') then
		present_state <= Idle;
		elsif (rising_edge(clk)) then
		present_state <= next_state;
	end if;
	end process;
process(present_state,next_state, enable, cyclecounter,done)
    begin
case present_state is
when Idle =>
	if enable ='1' then
		next_state <= Startadc;
	else
		next_state <=Idle;
	end if;
when Startadc =>
	if (cyclecounter >= 2) then
		next_state <= Listen;
	else
		next_state <=Startadc;
	end if;
when Listen =>
	if cyclecounter >= 14 then
		next_state <= Talk;
	else
		next_state <=Listen;
	end if;
when Talk =>
	if done = '1' then
		next_state <= Idle;
	else
		next_state <= Talk;
	end if;
end case;
end process;
  process(present_state,clk,cyclecounter,done)
  begin
  when idle=>
		cs<='1';
		done<='0';
		cyclecounter<=0;
	when startadc=>
		cs<='0';
		done<='0';
		cyclecounter<= cyclecounter+1;
		end if;
	when listen =>
		cs<='0';
   if(rising_edge(clk)) then
   cyclecounter <= cyclecounter + 1;
	internalbus(cyclecounter-3) <= serialin;
	else
	end if;
	when talk =>
		cs<='0';
		done<='1';
		bustofft<=internalbus;
	end case;
end process;
end architecture;
