jcl2000
5 years agoError 10818
I keep getting Error (10818): Can't infer register for "anglecodeunsign[1]" at AngleCounter.vhd(19) because it does not hold its value outside the clock edge
using this code
library ieee; use...
sstrell
5 years agoYou put the clock rising edge check inside an if check for an enable.
Your order for control signal checks for a register inference is incorrect. It should look something like this (you can also use a template in the Quartus text editor). Note that if you're trying to create a counter (not sure if that is your intention), anglecodeunsign is going to go back to the value of AngleCode every clock cycle:
PROCESS(clock, resetn) BEGIN anglecodeunsign <= unsigned(AngleCode); IF resetn = '0' THEN anglecodeunsign <= "00000000"; ELSIF rising_edge(clk) THEN IF enable = '1' THEN IF sclrn = '0' THEN anglecodeunsign <= "00000000"; ELSE IF anglecodeunsign > "00010000" THEN anglecodeunsign <= "00000000" ELSE anglecodeunsign <= anglecodeunsign + '1'; END IF; END IF; END IF; END IF; END PROCESS;
