18 years agoError 10327: Can't determine definition of operator ""+""
Hello to everybody, could someone tell me what's wrong in the following code? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity round16to12 is ...
10 years ago --- Quote Start --- why not post the actual code rather than post an explination. It could be several things wrong, but it will all come down to VHDL's typing rules. You did not explain why you are doing what you are trying to do. --- Quote End --- ok, I'm making an easy application of a genethic algorithm with an arbitrary fitness function to select the indivduals(8 bits random unsigned). The other solution i've tried is the following: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use Ieee.numeric_std.all; use work.genetica_type.all; entity binario_fitness is Port ( clk : in std_logic; individuos: in genetica; adaptacao: out fitness; somafitness: out unsigned (7 downto 0) ); end binario_fitness; architecture Behavioral of binario_fitness is begin process (clk) begin If (clk 'event and clk = '1') then for x in 0 to 49 loop adaptacao(x) <= (individuos(x) and "00000001")-(individuos(x) and "00000010") +(individuos(x) and "00000100")-(individuos(x) and "00001000")+(individuos(x) and "00010000")- (individuos(x) and "001000000") +(individuos(x) and "01000000")-(individuos(x) and "10000000"); somafitness<=(others=>'0'); end loop; end if ; end process; end Behavioral;
