16 years agoError (10293) architecture "fsmd_arch" does not exist for entity "debounce"
Hi everybody, I try to compile a UART test circuit with debounce. But, when I simulate the code, the follow error appear:
Error (10293): VHDL error at uart_teste.vhd(6): architecture "fsmd_arch" does not exist for entity "debounce" What is wrong in my code??? --############################################ library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity debounce is port( clk, reset: in std_logic; sw: in std_logic; db_level, db_tick: out std_logic ); end debounce; architecture exp_fsmd_arch of debounce is constant N: integer:=21; type state_type is (zero, wait0, one, wait1); signal state_reg, state_next: state_type; signal q_reg, q_next: unsigned(N-1 downto 0); signal q_load, q_dec, q_zero: std_logic; begin process(clk,reset) begin if reset='1' then state_reg <= zero; q_reg <= (others=>'0'); elsif (clk'event and clk='1') then state_reg <= state_next; q_reg <= q_next; end if; end process; q_next <= (others=>'1') when q_load='1' else q_reg - 1 when q_dec='1' else q_reg; q_zero <= '1' when q_next=0 else '0'; process(state_reg,sw,q_zero) begin q_load <= '0'; q_dec <= '0'; db_tick <= '0'; state_next <= state_reg; case state_reg is when zero => db_level <= '0'; if (sw='1') then state_next <= wait1; q_load <= '1'; end if; when wait1 => db_level <= '0'; if (sw='1') then q_dec <= '1'; if (q_zero='1') then state_next <= one; db_tick <= '1'; end if; else state_next <= zero; end if; when one => db_level <= '1'; if (sw='0') then state_next <= wait0; q_load <= '1'; end if; when wait0=> db_level <= '1'; if (sw='0') then q_dec <= '1'; if (q_zero='1') then state_next <= zero; end if; else state_next <= one; end if; end case; end process; end exp_fsmd_arch; --######################################### library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity uart_teste is port( clk, reset: in std_logic; btn: std_logic_vector(2 downto 0); rx: in std_logic; tx: out std_logic; led: out std_logic_vector(7 downto 0); sseg: out std_logic_vector(7 downto 0); an: out std_logic_vector(3 downto 0) ); end uart_teste; architecture arch of uart_teste is signal tx_full, rx_empty: std_logic; signal rec_data, rec_data1: std_logic_vector(7 downto 0); signal btn_tick: std_logic; begin --relacionando com núcleo uart uart_unit: entity work.uart(str_arch) port map(clk=>clk, reset=>reset, rd_uart=>btn_tick, wr_uart=>btn_tick, rx=>rx, w_data=>rec_data1, tx_full=>tx_full, rx_empty=>rx_empty, r_data=>rec_data, tx=>tx); -- relacionando com circuito debounce btn_db_unit: entity work.debounce(fsmd_arch) port map(clk=>clk, reset=>reset, sw=>btn(0), db_level=>open, db_tick=>btn_tick); -- incrementando loop de dados rec_data1 <= std_logic_vector(unsigned(rec_data)+1); -- led display led <= rec_data; an <= "1110"; sseg <= '1' & (not tx_full) & "11" & (not rx_empty) & "111"; end arch;
