15 years agoError (10028): Can't resolve multiple constant drivers for net "P[6]"
below are my code.
when I compile, Error (10028): Can't resolve multiple constant drivers... is coming out, anyone knows what's the problem? entity DU is port ( clk, reset, ctrlA, ldA : in std_logic; ctrlB, ldB, Psel, ldP : in std_logic; dataA, dataB: in std_logic_vector (3 downto 0); z, b0 : out std_logic; P : buffer std_logic_vector (7 downto 0)); end DU; architecture Structural of DU is signal Ain, Sum, dataP :std_logic_vector(7 downto 0); signal A :std_logic_vector(7 downto 0); signal B :std_logic_vector(3 downto 0); component reg8 port (ldP, clk, reset: in std_logic; data: in std_logic_vector(7 downto 0); Q : buffer std_logic_vector(7 downto 0)); end component; component shiftLreg8 port (d : in std_logic_vector (7 downto 0); w,clk,reset,ctrlA,ldA: in std_logic; Q : buffer std_logic_vector (7 downto 0)); end component; component shiftRreg4 port (d : in std_logic_vector (3 downto 0); w, clk, reset, ctrlB, ldB: in std_logic; Q : buffer std_logic_vector (3 downto 0); b0 : out std_logic); end component; begin c1: reg8 port map (ldP, clk, reset, dataP, P); c2: shiftLreg8 port map (Ain,'0',clk,reset,ctrlA,ldA,A); c3: shiftRreg4 port map (dataB,'0',clk,reset,ctrlB,ldB,B,b0); Ain <="0000"&dataA; process (clk,reset)begin if reset='1' then A <=(others=>'0'); B <=(others=>'0'); P <=(others=>'0'); elsif (clk'event and clk ='1') then A <= Ain; B <= dataB; P <= dataP; end if; end process; process (Psel) begin if Psel='1' then dataP <= A+P; else dataP <= (others=>'0'); end if; end process; process (B) begin if B = "0000" then z <= '1'; else z <= '0'; end if; end process; end Structural;
