12 years agoError : object used but not declared
I just want to create a signal_copie_req out std_logic : entity test_connexions is port( signals ... signal_copie_req : out_std_logic; )... COMPONENT test_connexions PORT( signals ... signal_copie_req : out_std_logic; )... i_test_connexions : test_connexions PORT MAP ( signals ... signal_copie_req => signal_copie_req, )... but I have this error that I don't understand : Error (10482): VHDL error at top_fpga_opg_master.vhd(3158): object "signal_copie_req" is used but not declared Error (10558): VHDL error at top_fpga_opg_master.vhd(3158): cannot associate formal port "signal_copie_req" of mode "out" with an expression Does anyone knows how to solve this problem ? Thanks
