11 years ago
erreur VHDL
Hello!
In fact,i have a small problem but I don't understand what I should do
here is my code:
library ieee ;use ieee.std_logic_1164.all ;
use ieee.std_logic_signed .all ;
entity M is
port(
        clk 	: in  std_logic ;
		rst 	: in  std_logic ;
		data 	: in  std_ulogic_vector(1 downto 0);
		CD 	    : in std_logic_vector(3 downto 0);
		s 		: out std_logic_vector (1 downto 0));
end entity ;
architecture beh of M is
signal com :std_logic_vector(3 downto 0);
begin
code :process(clk,rst)
begin
    if (rst='1') then
      (others=>'0')<=data;
       --data<='0' !!! ;
       (others=>'0')<=CD;
       --"0000"<=CD ;
       s   <=(others=>'0');
     else
        for i in 0 to 3 loop
          if (clk'event and clk='1')then
               --for i in 0 to 3 loop
                  com(i)<= not(CD(i) xor data) ;
           end if ;
        end loop ;
    end if ;
    end process ;
    s<=com(i) ;
    end architecture ;
This is my problem :
"""Error (10476): VHDL error at M.vhd(38): type of identifier "data" does not agree with its usage as "std_ulogic" type"""
Thanks in advanced.
    There are quite a few errors in that piece of code that you should think about first.
    To give a hint on the specific question, have you considered the width of the two signals you are doing xor on?
    Cheers
    Hi My friends !
    there is an option to attach file ?!
    anybody help me please !!
    Thank you very much
