12 years agoYour settings are appropriate.
You could also use "As input tri-stated with weak pull-up" if that device family supports a weak pull-up. HCT logic levels are TTL logic levels, so the 3.3V MAX output levels will be compatible with the HCT input logic levels. Cheers, Dave
